I can't read the actual size on them but I am inclined to say no. To give a real answer we need the wheel backspacing and actual tire size.
Well, I went and check these out last night and tried to put one on, the lug pattern worked but I guess that back spacing was off becasue the wheel would not fit flush against the hub. Is there some sort of kit I can buy?
If the wheel didn't fit flush against the hub, the hub center opening is too small. Those rims are likely lug centric and not worth chasing. Did the tires look as bald in real life? I think that's more trouble to make fit than the deal is worth to be really honest.
