No I don't currently own a Tundra. Last Toyota truck (of 5) was a 2002 Tundra. 122,000 mi, very little trouble.
I am in the market to replace my 2010 F150, Toyota is my first choice. I have read completely through the posting concerning the leak issue. I have also watched the posted video twice. I am retired and have a good friend who is also retired (toolmaker) that has 45 years of experience with motorcycle motors, 2 stroke, 4 stroke, single and double overhead cam engines. I asked him to watch the video. Other than not very clean, our main concern, without pulling the motor out so one can see the timing marks to make sure the cams are in time with the crank when reassembled, how are the mechanics positive the cams are not off by one tooth when reassembled and the timing off? It's easy to do without having a visual of the front on the motor, and maybe removing whatever to see the timing marks.
Motorcycle engines have cams attached directly to the head. If shims need changed, the cams can be removed without disrupting a sealed surface like these V8's. It just leaves another possible leak problem when reassembled. Assuming the crank-cam timing is correct.
I can live with the other reported problems being repaired if needed at the dealer, not sure I would trust the cam tower repair to them.
My Toyota relationship started in 1985 and ended in 2010. I didn't buy a 2010 Tundra because that was the year the 4.6L motor was introduced and I didn't want to take a chance on a new motor introduction. Ford's have plenty of their own problems.
Hoping that someone that understands the shortcut version of the cam tower leak repair has a solid answer for the timing question. Thanks in advance.
