1 - 9 of 9 Posts
Hello,
I noticed over the weekend that after a few minutes after turning the truck off there was a loud buzzing coming from the dash.
Is this normal and what would be causing this buzz.
Thanks everyone!
I think its probably the ac closing the outside fresh air intake.
Im pretty sure its the same noise but from my memory its definately not "Loud". If my truck wasnt in the shop Id go out and listen to it. Get in the truck and hit the recirculate button on/off and see if thats the same noise or similar.
Discussion Starter #6 (Edited)
It appears to be the dial for where you want air to come out at...when I move the dial to the floor only option it makes the noise...it seems sporadic..
Like it just needs some lube or something??
I have an '08 DC and I've got the same noise. I figured it was related to the climate control because if I've been driving with windows down and all climate control turned "off", I don't hear it. It's not every single time, but then again, I am usually out of my truck within about 15-20 seconds of killing the ignition.
1 - 9 of 9 Posts
