1 - 10 of 10 Posts
Several of the highways I regularly drive on in the Denver area are concrete with spacing such that the ride sucks at 60-75 mph. Like riding a bucking horse. Smoother at 55 and 80, but with 65 mph speed limit, neither of those is a good speed to travel. So, what suspension mods could help without sacrificing towing safety and off-road capability? I do more towing than off-roading. I was wondering if Air bags could be adjusted while driving to just change the dynamic enough to stop the bucking. Thoughts?
Add some weight as far back toward the tailgate as you can and play with the rear tire pressure to find a pressure it likes.
I realize my fix isn't for everyone, but found a camper shell helped my issue.
Tundra Camper R:R-1.jpg
I have a 16’ dbl cab with a 7” BDS lift with 37” MTs. I was smoking the Fox rear shocks, partly because they were horrible and partly because C-470 concrete is brutal, especially on an empty bed. Installed Bilsteins and its alittle better but the harmonics are still there. In the bed I have a topper with a full RhinoRack complete with HiLift/ axe/shovel, awning/ full sized spare and recovery gear in the bed, so probably 500#+. I dont get down to the city much, so its an issue I just deal with as I live in the mtns. You can check out the rig at: www.grizguides.com/sponsors
I have had 4 Tundra's, and the best for highway hop is the stock black shocks. The bilstiens tend to be a little stiffer ride. But the best solution is to add a couple hundred pounds of something like sandbags, topper, etc back there.
If you are having this more with a big trailer attached, then sometimes adjusting the equalizing bars either tighter or looser can make a big difference, and sometimes going to stiffer bars will help. But adding shocks to the trailer axles is the real solution!
Same here on my 2015 DC 5.7L. Southern California concrete freeway expansion joints (only in certain areas, like the main freeway through my city!) set up a wicked vertical vibration in the rear of the bed that shakes the whole vehicle. I can watch the rear corner of the bed rapidly vibrate up and down at least an inch. I believe that it is primarily caused by the non-boxed rear frame under the bed being too flexible for the unloaded bed.
As you point out, it is a harmonic, tied to a particular frequency of vibration which is a function of the distance between expansion joints and their height. For me, it manifests at all freeway speeds between ~65-80mph. Slower, it isn't fast enough to resonate. Faster, and the bump frequency between the expansion joints cancels out the frame response.
I'm running 2.5" rear Icon resis w/ the CDCV and I have tried all the settings. Nothing helps. I have a beast of a Hellwig rear sway bar (#7692, 1 1/8" dia) and it too doesn't change anything. I have tried all different rear tire pressures (Michelin Defender LTX LT295/65R-18 123Q 10-ply).
Absent significant frame reinforcing, and coincident with others' replies here, I have concluded that only weighing down the bed will cure it. It's really the only thing I seriously dislike about this truck.
1 - 10 of 10 Posts
