2008 tundra reak lights staying on. Switch on break pedal is working fine. If I pull to 30 Amp tow brake fuse brake light go out. Anyone ever have this issue
Did you check your master cylinder reservoir, could be its low or a bad sensor.2008 tundra reak lights staying on. Switch on break pedal is working fine. If I pull to 30 Amp tow brake fuse brake light go out. Anyone ever have this issue
