1 - 4 of 4 Posts
Hi guys
Winter winding down up here, looking to see what is best for our tundra with water based paint lol, as I need a degreaser of sorts to remove undercoat that has seeped as well as just nasty road grime
I have some that we used at work, but it's an acid based, and I just wanted to see if there were any better ones for the newer paints
Thx
Are you using it on the painted body pannel or the under carriage? If you are using it on the body, I would skip the degreaser and use a claybar. If you are using it on the under carriage I would use Chemical Guys Red Hot Degreaser or Grime Reaper.
Sent from my SM-G900V using Tapatalk
Reactions: Dixon Cider
Discussion Starter #4
hi
Using on bottoms of doors, tailgate etc and basically there is a thick grime all over truck, it will come off with soap and water, but very heavy to do etc
The for the tips guys
1 - 4 of 4 Posts
