Glad I could help. Going to take it back to get the alignment fixed. They put .5 degrees positive camber in it and I want that to be negative.
The pics of my truck are in the middle setting. It is NOT completely level. The front rides about 5/8" lower than the rear.I've got these on order for my 01, should be in any day. The guy from shockwarehouse told me I should use the middle setting to level it out. I've seen vids that show that some of these shocks have 4 settings; Stock, 1", 2" & 2 1/2" I measured ground to top of fender and it's 34" in the front and 36" in the rear. I read somewhere that the bottom setting is already a 1/2" higher than stock height so I guess I would just go directly to the 2" setting since that's my difference. The vid I watched with the 4 setting 5100's was for a Tacoma, can someone confirm that the Tundra's are only 3?
So my shocks came in and there is indeed 5 settings (see pics). My front rde height is 33 1/4", rear 36" so I'm gonna go all the way to the top with these to get as close to level as possible. Correct me if I'm worng.The pics of my truck are in the middle setting. It is NOT completely level. The front rides about 5/8" lower than the rear.
oh and only 3 slots to choose from.
