81 - 89 of 89 Posts
My set up is +1 off set. That may be why I got the rub issue.
Did you go with 295/70-18's and trail grappler tires? Which rubbing issues did you have? Which level kit are you running?
And last but not least can you post a picture of your wheels?
EDIT: I was mistaken. Fuel apparently only offers the Trophy in 18X9 with a +20 offset. I think I was thinking about the Methods as that was initially my wheel of choice until I found the trophy.
Banned
Yes i had rubbing issues. body mount had to trim minor amount. front plastics were trimmed by the shop. little pissed about it. plenty of room to heat up and push back. i have a 2014 dc 8' bed 4x4 with ready lift 3/2. rims are fuel throttle 18x9 with +1 offset yes the tires are the trail grapplers 295 70 18. they hum
I've got 305/50R20 Nittos on 9" wide +40 offset BBS wheels, they just touch the skid plate at full lock. This set up has the same diameter as the tires that came stock on the truck, but are 2" wider. Truck is leveled with 5100s on the front on top setting.
275/70r18 bfg ko2's truck is stock!
81 - 89 of 89 Posts
