1 - 13 of 13 Posts
the BIG 3/4 0 GAUGE UPGRADE
so sorry, what i meant was 0 gauge power upgrade in the engine, example: power cable from the alternator to the battery, from the negative battery to the chasis, and from the negative to the engine block.
>:D:D:auto::bounce::doh::doh::mechanic:
I have done the big 4 for the Tundra (with pictures) but not in this forum
can you send me the link? thanks
To what? There is no off the shelf kit for this. I had to measure cable length and size out each piece for a complete custom build. I bought everything from ebay seller gregsmarine. They will terminate the cable to whatever you need. For my build I used 2/0 SGX cables. They seemed pretty flexible for their girth.
I highly recommend buying your cables pre-terminated with adhesive-backed shrink wrap. Unless you have the proper equipment to crimp 5/8" thick wire. And don't mess around with screw tightened cable ends.
Check PM.
1 - 13 of 13 Posts
