1 - 13 of 13 Posts
Besides dedicated snow tires.
What would be the best tire, bigger of course would work best plowing snow.
I have used snow tires on sport cars before and I know how great they are.
Just would like to stick to ONE set for the Tundra.
This would be on a Level kit lift only. Bilstien 5100 shocks up front.
Thanks guys!
Duratrac's are good in the snow and my Toyo AT2's (extreme version) are very similar in snow.
Last time I checked it was White and cold to the touch.
Its thicker or lighter based on where you are. For instance, Utah's snow has a low moisture percentage, so less gnarly tires are needed, whereas Montana has a really high moisture percentage, so more dedicated snowtires are needed.
I would say more of a wet snow then. Does Blizzak have heavy duty sidewall tires?
Thanks
Blizzaks is not suitable for plowing. Everything is too soft. Toyo has a good ice tire that is much stronger and better in wet snow.
Thanks vball!
Never heard that about the blizzacks ? It is the sidewall that is too soft?
I will check out them toyo's.
1 - 13 of 13 Posts
