1 - 2 of 2 Posts
No expert by any means, but did my due diligence to research what suspensions advertised being able to run 35". Tundra has been great in the desert, but I need a little more clearance for rocks.
BDS Toyota Tundra 4.5" Suspension Lift Kit 2016-2019 4WD
https://4x4.fatbobsgarage.com/bds-toyota-tundra-45-suspension-lift-kit-2016-2019-4wd-p33728.aspx
Fabtech 4" Basic Lift Kit
https://realtruck.com/p/fabtech-4-basic-lift-kits/v/toyota/tundra/2018/
Fabtech 4" Coilover Lift Kit
https://realtruck.com/p/fabtech-4-coilover-lift-kits/v/toyota/tundra/2018/
Pro Comp 4" Stage I Suspension Lift Kit with ES9000 shocks
https://www.morris4x4center.com/pro-comp-4-suspension-lift-kit-with-es9000-shocks-pck5079b.html
https://www.4wheelparts.com/p/pro-comp-4-inch-lift-kit-with-es9000-shocks-k1159b/_/R-DFCW-K1159B?gclid=CjwKCAiAzuPuBRAIEiwAkkmOSFmd9q3lmioqkJehOx8TnJlwqlrxIWXbVWl6tf1SelVaB1EGrbliKxoCGvQQAvD_BwE&ecmp=s:google_1749763888_65275301221__pla-670217928415_Pro Comp Suspension_EXPK1159B_base_US&utm_source=google&utm_medium=cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&utm_source=google&utm_medium=cpc&sc_intid=EXPK1159B&ef_id=CjwKCAiAzuPuBRAIEiwAkkmOSFmd9q3lmioqkJehOx8TnJlwqlrxIWXbVWl6tf1SelVaB1EGrbliKxoCGvQQAvD_BwE:G:s&s_kwcid=AL!7836!3!340663032463!!!g!670217928415!&utm_source=google&utm_medium=cpc&utm_campaign=SC Shopping - NTM Desktop&ecmp=s:google_1749763888_65275301221__pla-670217928415
ReadyLift 69-5475 4" SST Lift Kit
https://liftkits4less.com/readylift-69-5475-4-sst-lift-kit
ReadyLift 4" Lift Kit
https://realtruck.com/p/readylift-4-complete-lift-kits/v/toyota/tundra/2018/
Rough Country Toyota Tundra 4" Suspension Lift 4WD 2016-2019
https://4x4.fatbobsgarage.com/toyota-tundra-4-suspension-lift-4wd-2016-2019-p33762.aspx
Superlift 4.5in Toyota Lift Kit
https://superlift.com/4-5in-toyota-lift-kit-07-18-tundra-4wd/2017/toyota/tundra
SkyJacker 4.5 in. Front Strut Spacer Suspension Lift Kit w/ M95 Performance Shocks
https://www.extremeterrain.com/skyjacker-tundra-45-inch-front-strut-spacer-suspension-lift-kit-m95-performance-shocks-tu745bkm.html
Tuff Country
https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=23306
Drop bracket lifts that lower the front crossmember will not increase ground cleance, if you are really 'using' the truck offroad a spacer lift is no good either. You want quality coilovers and uca's, a 3" lift is more than enough for 35's and minmal trimming if you are careful with the backspacing if changing from stock wheel. Shackles or a springpack out back.
1 - 2 of 2 Posts
