1 - 2 of 2 Posts
Hello. Have a ‘19 Crewmax with deck rails. Just received the Bak revolver x4 however it does not include the brackets to lower the rail system. Is the rail system needed for the bak install? If not I’ll remove them altogether so I can install the clamps... no plans to use the rails otherwise. Any input greatly appreciated. Nick
I may be off base here, but I used to have a '14 Bak roll-x, and they had the long, flat brackets to lower the rails.
When I looked at the newer BAK models, it looked to me like they changed the mounting bracket and that the lowering brackets were no longer used, just had the rails bolt into the mounting brackets about an inch below. This was shown in the supplement instructions for the Tundra. See:
The bracket they show is a lot like the bracket used by the tri-fold OEM that I bought.
1 - 2 of 2 Posts
