Installed backup lights in rear bumper with red + and black -
Bought an aftermarket harness on Amazon w/ 3 pin switch and relay. Instructions say to wire both positives to the battery and both grounds to frame. Problem is led lights on switch stay powered even when truck is off. Should the positive for the relay be wired to radio, cig lighter etc? Switch is #7 ground #3 power in #2 load
Also lights do not turn on, all connections are solid and wired correctly with black to black & red to red
