I got it all together and it works.
I went 1.5" shorter on the rear driveshaft; as the difference in the case length was 1.4"; and it worked perfectly.
I used the sequoia front driveshaft, which measured 33.75 inches end to end.
Instead of using a secondary light - i used the light in the switch.
It does work as I wanted - but it is not bright enough.
Im going to order an extra switch (incase I break it) to take apart and put a brighter LED in it.
