1 - 20 of 26 Posts
I currently run 5100's at middle setting with two CB shims each side. This setup gave me around 2.5" but it took two tries at the alignment to get good numbers. I will probably take out at least one shim but I would also like to go up a few more inches. After speaking with David Ekstrom from Coachbuilder, it would appear a spindle lift is compatible with my existing setup.
Has anyone gone with spindles? If so what is your impression?
Sitting in my office as we speak. They dont effect ride. I have the Maxtrac ones.
I have run the Maxtrac spindles for over two years now and love them. You will have no problem with alignment. They keep all angles stock. I highly recommend them for lift if you are 2WD. I installed them myself. Not a tough job. Only took about 3-4 hours and 3-4 beers. :)
Hardest part or any tips to give? I'm thinking of trying friday while all the shopping madness is going on
I currently have the CST Spindles with Bilstein 5100 in the front. Going to swap out the Bilstein's for Icon Coils. I like the ride of my current setup.
You guys running spindles and 5100s should post up a few pics of your truck. Love to see the wheel clearance.
Discussion Starter · #9 ·
Thats about perfect, what tires are you running?
The install was pretty straight forward. I just followed the included instructions.
Needs bigger tires now.
Bilstein 5100's
2 CB shims per side
maxtrac 3.5" lift spindles
and a 3" block in the rear (for now) with Zone offroad extended shocks
Bilstein 5100's
2 CB shims per side
Nice!!! looks great! I added an iron bull bumper and lost some height in the front with 5100s on the middle setting with CB shims. Thinking the spindles are the way to go to add some height back.
Installed my MaxTrac spindles myself as well - not difficult, the instructions were pretty good. Need some large sockets for the lower ball joint and may want to consider Coachbuilders tie rod ends. No issues with getting it into alignment, its a very smart way to lift a 2WD.
Discussion Starter · #17 ·
Throw a picture up here, we would love to see the truck with spindles. Also tire size;)
Id say thats about a perfect tire to lift ratio.
I'm happy with it, like the higher driving position as well. But the trend lately seems to be towards less lift and more tire.
For 2WD spindles are an ideal way to get lift with minimal impact on suspension geometry. If you did spindles alone in front with 1" rear lift (via shackles) the truck would still drive pretty normal and you could still tuck 35's in there with the correct wheel offset. Some are even getting 37's with minimal lift.
Another thing to keep in mind, with 35's (and even more so with 37's) your effective gearing changes, and if you are like me you will want to go to 4:88's to compensate. Then while you have the diff out you'll want to add the Auburn LSD (next to the SC, these are two of the best bang for the buck upgrades on the 2WD tundra). And then you'll want traction bars to reduce axle wrap. And the rear sway bar to help with cornering given the higher center of gravity. There is more you could do, but I decided to stop there. Seems there is no end to the money we can spend on these trucks.
1 - 20 of 26 Posts
