I can’t find this anywhere. Seems like everyone is running 20” wheels or smaller tires with the 5100’s. I currently have a leveling spacer on my 13 2wd dc. I think it’s 2.75 or 2.5”s. Tires are 275/70r18’s. I have a brand new set of st maxxx 295/70r18’s sitting in my shop. I have decided to replace my shocks. 80k miles on the truck and figure I would go with the 5100’s and get rid of the spacer. The wheels are aftermarket with a +15 18x8.5. Will I have any issues with fitting these tires?
Should be just fine on top setting. If you want to be safe order a pair of coach shims for an extra half inch. Good luck and keep us posted!
If you don't want rub, you'll need to trim. Might even need a BMC depending on how your alignment is done. If you had +35 to +60 offset you'd need minimal trimming and there'd be no chance of needing a BMC.
Unfortunately the lift doesn't help with rubbing, and going >2" causes other issues, like crappy caster and needing UCAs. If you put shims on top, you definitely need to extend your bumpstops.
I think you'll have to trim, but I'm no expert. I'm running 5100s on top setting , CB shim per side, +1 offset with 305/65r18 (33.6 inches) tires and had to remove the front mud flaps and trim the front fender liner a bit. Nothing major or complicated
I just had Bilstein 5100s installed on all 4 corners and 1 shim each on the front. And I think I’ll have to do the bmc. Also had to trim front fender and removed front mud flaps.
20” wheel, 275/65/20 tire size.
