I posted this on another thread, but I have more questions than just the water pump and am looking for some high mileage OG Tundra owners advice...
I'm at 88k and out of warranty, went in to the stealership as I get free lifetime oil changes so i take advantage, but I don't let my truck out of my site when there. I still bring my own Mobil 1 mpg booster full syn 0W-20 but its nice to have them do the rest of the work. While in there I was asking the service manager what problems he's seen with Tundy's naturally the water pump issue came up. We both looked at mine he says he could tell its leaking. I saw a little white crud but not much pink stuff nor have I ever noticed puddles of pink coolant underneath my truck when parking for a while. It was hard to peak in but he did have a mirror on a stick to sort of see inside. My coolant level was damn low too, but it had been 8k since my last oil change. Also, I think I'm going to start changing my oil at 5k even with the full syn mobil 1. Cause my oil was pretty damn dark this time around.
Question is I will monitor the supposed leak and see if its bad, but if its a slight leak how or when should I change the water pump and how big of a PIA is it to do yourself?
Also, being that I'm almost at 90k I've seen the recommendation for 90k to change transmission fluid, is this what everyone here has done?
Also, my power steering pump went at 60k and I had it replaced. It looks kind of dark in the container but when you dab the dip stick on your hand its still pretty golden. How often do you guys change your power steering fluid? The stealership guy first thing he says is you need to change it every 30k and hit me up for it as soon as I pulled up without even lookin at it so I know he was trying to up-sale me. Regardless, i will do it myself anyways, but how often?
Also, for those with 4x4's what about your differentials how often do you change out front and rear? I do not use 4x4 very often maybe once a month just to keep it in working order or if I'm out mudding.
Besides transmission fluid and the above fluids what else would any of you higher mileage guys recommend you did at either 90k or 100k? How soon did you guys change out your spark plugs?
