So after months of lurking on this site....I decided to take the plunge and have the LRO 3/1 kit installed by a local shop. Like a kid on Christmas i was fired up. The install went well and I provided the specs for the install to the shop. Truck looks awesome and so far I am happy with the work. However, I do have a question about alignment.....LRO gave specs for the alignment as follows (Camber 0 deg left & right, Caster 2 deg positive left & right, Toe 1/32" 0 deg 4.5" minutes or .075 decimal degrees). The shop was able to align the front to the following LF .3Deg camber 1.6 deg caster, toe 1/64" & RF .2Deg camber 1.6 deg caster, toe 1/32 (total toe 3/64" Steer ahead .01deg). I know squat about this topic and my head started spinning when i typed this.........The truck drives straight and we (mechanic & I) didn't notice anything during the test drive. So is this "OK" or should I be going back to express some concerns?
Do you have any steering wheel wobble while you're driving?
No, not at all. She drives the same as before. Am i just being a bit on the over reacting side of this, or does the Mfg spec have to be exact?
Unless you notice any unusual wear on your tires, you're probably good to go.
Thank you........I'll watch the tread wear. :) loving the level kit even more!
