1 - 8 of 8 Posts
I needed an USB charging port to be in any of the blanks below the AC control, all of them have some connector with wires attached.
what are those for??
Thanks in advance
Discussion Starter #6
Here is how it looks, I got the charger from amazon but had to do some mods to make it fit, had to remove the tabs too & bottom and do some filing to remove a little bit too and bottom and create a little notch about 1mm wide so it could secure in place, on the sides everything was ok, I tapped it to the RH lighter hot and ground.
I would also like to add some usb ports in this area. I would like to put them underneath where the switch and charger are. The pebble grained panel. How can I find out how to take the panel off? I would also like to add a charger panel on the back of front seat. I have a bench seat and I do have a power outlet on the middle front seat. I would like to add usb ports so I would not have an adapter plugged in and chance it getting damaged by a wayward kick. If anyone can point me in the right direction I would be grateful..
1 - 8 of 8 Posts
