2001 Tundra V8. I have replaced the AC compressor and the drier cause the AC wasn't working. The light was flashing, and the clutch engages for few seconds then stops.
A mechanic told me it was the compressor, so I replaced it along with the drier.
I pulled the vacuum and leak test, and checked good.
I added some refrigerant. The clutch engaged for few seconds, and then back to the same symptoms again.
It did not wanna take any refrigerant since the clutch isn't engaging, but it does engage for few seconds every time I turn the AC off and on.
I could only find one pressure switch. I thought I was suppose to have two.
My next replacement would be the switch and the expansion valve.
Anything else you guys might suggest?
