Hey guys, I have a 2014 tundra with the 5.7 4WD. I was on the highway the other night coming home and out of the blue the traction control kicked on for no reason, it was dry roads but very cold out. This limited my engines power and then my power would come back and then the truck would do it again so I had to pull over because I could no longer accelerate. I immediately pulled off the highway. The truck went into some kind of safe mode id assume because now I can drive it. It drives great it just has the slip indicator light stuck on and abs light stuck on with 4HI and 4LO flashing. 4HI and 4LO don't come on until after I start moving after starting the truck up. I can put it into 4wd before the lights start flashing and it locks in but never after the lights flashing. Does anyone have any idea what could be causing this? I searched the forum already and found a few people with similar issues but not identical to what I have going on. Figured maybe someone here had this exact same issue nd could shed some light on it.
thanks guys.
thanks guys.
