2011 5.7 Tundra Rock Warrior.
Anyone have any troubleshooting steps for the ABS/VSC/TCS system?
Soft pedal (to the floor), so I replaced the master (yes, I bench bled). No change.
The issue is I can't hear the pump when key-on after removing pressure with key off (m/c bleeding procedure) and when bleeding the rear brakes, there is no evidence the pump is working.
All the fuses appear to be good. No dash lights present. ABS/VSC tries to work (ie. I can hear and feel the actuating and the light appear until stable), but nothing actually happens.
The other giveaway is I spin tires at most intersections without trying.
Before I fork out the coin for the pump/module, I want to make sure I'm not missing something else.
No signs of any leaks. I have tried re-bleeding the system with my Motive pressure bleeder with no success.
Any suggestions?
Any suggestions?
