1 - 8 of 8 Posts
Can I run my 6112 at 3rd clip on left and 2nd clip on left to level truck. This what my suspension guy is recommending. Both are at 3rd setting now and my right front is about .6" higher.
What do you think?
I would add a shim before I ran them and different clip settings.
Reactions: 1lowlife
Won't the shim basically do the same thing? If I put a shim on the left side it's going to raise the left but also make it slightly stiffer. If I lower the clip on the right it will lower the right and make the right slightly softer?
Is there any danger at running them at different clip heights?
Why would shim on the left make it slightly stiffer? Shim is above the tophat so spring preload is unchanged.
Ya, the shim won't make it stiffer, but using a taller clip will. I don't think that's a bad thing though. It's leaning because there's more weight on that side.
1 - 8 of 8 Posts
