41 - 60 of 205 Posts
Thanks, hope to do the flush next week. I picked up 12 litres of WS fluid today, at $7.25 CDN per litre. I caused quite the contraversy at the dealership. First the parts person told me that it never needs to be changed, to which I corrected them and informed then the maintenance schedule shows it should be changed. Then the head tech came out and made sure I knew how to check the level! I guess it was good they look out for the customer, but I swear the parts lady wanted to talk me out of it.
So I finally did the fluid change, and it went well. A couple of points, I used a 3/4" OD and 5/8" ID hose to feed the tranny. This fit my tranny funnel perfectly but was too big to go inside the fill point. I ended up having to taper the hose. I'd say 1/2" would be probably the biggest that would fit the fill hole.
I also used the "non techstream" method for the tranny temp, whereby the shift indicator uses the "D" light to show the temperature (by being off, steady or flashing). Worked great. I measured the pan temperature with a IR temp gun when the temperature was correct, and there was a signifcant difference in the pan vs fluid temperature so I wouldn't recomment using an IR temp gun for accurate temps. Below are the instructions I used:
View attachment 2007-2008 Tundra Trans Fluid Level Check.pdf
I also disconnected the cooler line at the cooler, which was much easier than doing so under the truck. I just pulled the top line, connected a 3/8" line to the cooler barb and it pumped out perfectly. It's easier than being under the truck (unless you have a hoist).
With 12 Litres of Toyota WS, the tranny shifts better than ever. The old stuff was due for a change.
Did you open the thermostatic valve while you pump out the fluid? I take it you pumped out a certain amount and then put that same amount back in, and kept doing that until the fluid that came out was clean. Then you do the checking of the proper amount of fluid?
Yes, I opened the thermostatic valve. I basically did the same as the original posters instructions, except for the fact that I disconnected the line at the tranny cooler.
I pumped out 2 litres at a time on a marked translucent jug. Then poured 2 litres of new stuff in the trans. I had my wife start the truck, and I'd tell her to shut it off once it got to the 2 litre mark. I have done this method before with other vehicles I have owned too. After all the new fluid was in (I think I put in slightly less than 12, because the pan was about 3.5L or so), I checked the level.
I can't snap a pic now, but I disconnected the hose right at the cooler it self. Just open the hood when you find the tranny cooler your find the lines.
Here is a pic of a tranmssion cooler and it's lines for a better idea of what I am talking about:
Discussion starter · #54 ·
Dumb question, but does it matter which line you disconnect?
if you want to remove the fluid in the cooler remove the return line. if it's not an issue to you the feed line is ok. considering you have to open the tranny thermostat it's not a big deal to disconnect the line under the truck.
either way will work though.
I disconnected the upper line, which if I remember correctly, was the feed line to the cooler. I just connect that to a barb and a length of 3/8" hose to a container. You could disconnect the return line too, but you'd have to put the hose on the cooler rather than the line.
I found it much easier to disconnect it at the front of the truck versus under where there is hardly any room to wor. Plus, I could just stand at the front of the truck when pumping the fluid out and easily communicate with whomever is operating the truck. Either way works, but this way is easier IMO.
I read thru most of this thread and I can't recall seeing any mention of a pan drop and filter change after the flush?
Is there a filter?
Is there a filter?
I just jumped right to this last page out of interest since I already have done my DIY tranny fluid replacement a while back. I did drop the pan on mine and took a photo of what the inside looks like from another same type tranny I picked up (spare!?)
Here it is, the Valve Body and the Filter..
