If you're looking at spacer leveling kits they're all pretty much the same. Just pick one.
You mentioned possibly looking into more of a lift- With a 2wd you have lots of options-
CST spindles- 3.5" and your truck will still ride like stock. If you want more you can add a 2 or 3" leveling kit. If you still want more you can use OME coilovers instead of spacers. You should be able to get 4" out of the OME coilovers for 7.5" up front if you want that much. If you go above 3" with the coilovers you probably need upper control arms too.
Once you decide on the front you can start figuring out the rear- CB 3" shackles will get you the first 1 3/4" in the rear. Then you can look at leaf packs or blocks.
