Do you have a pic of the stance your truck has now? If you're with .50"-.75" of sitting level chances are the VSC will engage or malfunction any time your truck corners hard are under hard acceleration. The sensor sits at 2.20 degrees from the factory, if the ZPC DaveB702 mentioned doesn't eliminate it you'll need to shim the sensor. (under the center console)
