1 - 2 of 2 Posts
A gentleman is offering me a great deal on 5x150mm 18x9 -12 offset Ballistic Rims with 35x12.50 Hankook tires. I have a stock 2007 Tundra that hasn't been leveled or lifted as of yet. I see a lot of numbers and math on here, but I don't quite understand how it's done. Will these fit stock? If not, will they fit with adjustment and what would that be?
That setup is likely going to need a lot of cutting to not rub no matter your suspension setup unless you go to a full 6" lift. The negative offset on those wheels doesn't play nice on a tundra. If your willing to do the bmc, trim and space out the front bumper you might be able to run them with virtually no lift.
Sent from my SAMSUNG-SM-G930A using Tapatalk
1 - 2 of 2 Posts
