1 - 4 of 4 Posts
Hey guys,
I know there is a ton of "Will 35s fit!" Threads but I typically only see people running 3/1 kits asking. I am asking because I am only running a 3" lift in the front. My rear is stock height. From what I can see a 35 will fit no problem on a stock rear and lift front but figured rather than screwing around with a tire shop I will ask everyone here.
Just for anyone curious I run 18x9 Method Double Standards and I am jumping up from 305x65x18 Falken Wildpeaks to 35x12.50x18 either KO2s or Ridge Grapplers. Still in a toss up. Leary of the KO2 cause from what I have seen from friends BFG wear extremely fast.
1st of all, a Nitto will be noticeably larger than a BFG. My last set of 35" KM2's only measured 33.5".
and 2nd ... what is the offset of the wheels?
I run 35s with NO lift. I have very little rubbing in the front (I did the mud flap delete on all 4) and none in the back even with full suspension travel in any direction.
Sent from my iPhone using Tapatalk Pro
1 - 4 of 4 Posts
