1 - 4 of 4 Posts
Anyone know if this size will fit a 2013 DC without rubbing or modification?
Most likely not because of the width. But if you're looking for a tire that's about 33" tall and should fit without a level then 275/70R18 and 285/65R18 are both options.
Read Only
mine fit with a 3/1... had to remove the small rectangle flaps in front of the wheels... but that's it. They almost fit without the lift. All I would've had to do is pull the fender liner towards the front 1/4 to 1/2 inch. Of course that's with +30 offset wheels
1 - 4 of 4 Posts
