1 - 6 of 6 Posts
325/60/18 on 8 inch wheel?
I have a 2008 Tundra and purchased a 3/1 level kit off ebay to level it out. Im going tomorrow after work to a buddy's house to install it.
But not only are my current 275/65/18 most likely going to be too small, but they are pretty worn. So I found a very nice set of 325/60/18 all terrain tires with about 70% tread left locally for a really good price I almost cannot turn down.
My question is, these tires are going to be even shorter than the tires I already have, but obviously wider. Iv never really had all terrain type tires with meat before, will these look taller and fill in more than my basic 275/65/18 tire I have now?
Will these need any altering at all or will they be fine to just throw in there?
Discussion Starter · #2 ·
I guess another question I need to ask is, will these tires even fit on my wheels?
I have a 2008 Tundra Texas Edition with the enkei wheels that were recalled. Im not sure of the wheel size itself though?
after searching the web, these wheels are 8" only, so im guessing these 325s wont fit. What do you think, 285 max?
you may have some uneven wear if you put a 325/60/18 on a 8" wide wheel. Also, the offset of the stock wheel is going to give you problems.
without seeing a pic of the actual wheel... I would say they are +50mm offset.
1 - 6 of 6 Posts
