1 - 18 of 18 Posts
Hello, I'm about to pull the trigger! I have a 2011 Magnetic Grey Tundra CM 4x4 5.7L with color matched BW fender flares, LRO 3/1, 2" shackles are coming from coach. Was wanting advice on this Fuel kranks 20x9 +1 with 305/55 AT2. what mods will i nedd to do to prevent rubbing? Sorry for the rookie question! It my first set of rims and tires! Thanks Jeff!
i have basically the same setup and all i had to do was remove the mud flaps and push the front fender liner in a little bit and attach it...it's no big deal
With +25 offset I only had to push the front liner in a bit (loosened screws, pushed on liner and re-tightened screws. Kept mud flaps and no rubbing.
13-14 according to the computer mostly city with a bit of highway. Towing the trailer this week so I can let you know those results this weekend then going on a 5000km round trip without trailer. Don't worry about mileage, they look great! Lol
Looking to run same setup without rubbing or tires coming out past fenders.
Acejack, with the +1 are your tires sticking out past fenders?
Thompsonreido, are you running 305's on your 60mm offset wheels? Did you have any rubbing that required major cutting/mods?
Bowyota, how's your setup coming?
Thanks guys!
"The Midnight Modder"
I think if you stick with the 30 something offset or higher it will not come out past the fender. I have 18mm offset and it comes out about a half inch or so. OEM flares are just enough to cover tread.
Y'all with 305 plz share your MPG? really like to know soon... Thanks in advance.
i got about 15 to 16 before level and tires now it's about 12 to 13 all hand calculated including the extra miles gained with the bigger tires
Looking at some Fuel Offroad wheels with a +25 offset. No rubbing issues with the +18 offset on yours?
breauxmeister, what is the offset on your wheels?
Thanks guys, cheers!
Thanks guys!
here is a couple pics. tires stick out a tiny bit.
+1 offset
9-10 mpg towing trailer 100-110 km/hr (all according to computer)
Went for a day trip (all highway) 100 km/hr cruise control and got 17.9 mpg.
Thanks guys!
+25 offset with 305's no rubbing
1 - 18 of 18 Posts
