1 - 20 of 22 Posts
Same tires I got they only rub with full lock in reverse with a +10 offset.
I have been told they will by many people
there are "many" people here also saying you'll be fine!
since you already ordered them, looks like we'll find out! :lmao:
Read Only
Before my 3/1....Mine only rubbed at full lock in reverse... just barely on the front of the fender liner (this is also with the small mud rectangle front mud flaps taken off). My wheels are +30 offset. Even with the 3/1 I had to leave the small rectangle front mud flap off due to slight rubbing at full lock.
F&@k Y'all, I'm from Texas
Mine rub at full lock in reverse. It definitely does not rub the front since I have nothing to rub there. I think it rubs the mud flap but I don't care enough to check it.
Your front tires should be at a high psi since that is where most of the weight is when running empty.
your running these wheels right?
they are +50 offset I believe. the rub/no rub issue I'm sure has to do with offset given the same tire size, plus possible differences in measurements from one tire manufacturer to another
My wheels are +35.
Sorry, just to clarify I was talking about the op's wheels.
I do mostly city driving, not enough highway to get a good reading. It's not great, but don't own a truck for fuel mileage. I haven't noticed a difference between these and the 275/70 BFG's I took off.
1 - 20 of 22 Posts
