1 - 20 of 37 Posts
What are your inputs on using the low profile Harbor Freight 3 ton jack on my 2015 Tundra 5.7l? This is the only jack I have and I don't wanna buying another one if I don't have too. My Tundra weighs a little under 6k pounds so I'm really pushing the limits of the jack already. It looked sketchy the last time I used it to rotate my wheels.
While a bigger jack would be better it’s not like you’re lifting the whole truck so you aren’t technically surpassing the jacks capabilities. I would however you jack stands regardless because jacks can still fail.
^^This.
Tire rotation is one of those tedious tasks, but I do it on my 2015. Owner's manual only shows front-to-back-to-front rotation, so I loosen lug nuts, get the whole side up onto jack stands, and then remove the wheels, swap positions, get 'em snugged and then off the jack stands.
I will NEVER rely on the jacking mechanism to hold the vehicle up while I'm working on it. The ONLY exception will be in a roadside tire change situation, and then I won't ever put myself under the vehicle while it's supported with a jack only.
I use the same jack, you will be fine. I even made an extender for mine since it barely got my wheels off the ground with my lift. Northern tool sells some nice and tall 6t, I think, jack stands for a good price if you need some.
It's not load rating that will be the problem with your HF jack, or any floor jack for that matter.
If you're lifting one corner at a time (recommended, with jack stands), the jacked load will be less than one third of the jack's 3 ton rating. This DOES NOT consider that your jack may not have it's original rating due to age and wear. I suspect the more likely problem for your floor jack will be maximum jacking height at most frame jacking locations. My HF floor jack appears to have about 15"-18" maximum lift height.
The road clearance on a Tundra will probably require you add stable blocking to the jack lift platform if you want to jack on the frame; Or, you will need to jack only on "designated areas" of sprung suspension components; e.g. on lower control arms, rear axle housings, etc. Once the springs begin to stretch out on frame jack points, you'll likely run out of jack height before the tire is off the ground.
But, if you've rotated the tires once, you either realize this already, or were lucky in your choice of jacking points.
I have use my HF 3 ton on the Tundra for several years with only 1 problem, it leaks down slowly no matter what I do. I also use it on our Sprinter van which weighs about 8500#. Definitely use jack stands though!
Other than the gdamned handle pulling out of my hf jack, same 3 ton lp version, it is fine for my truck.
I jack up the rear at the center of the pumpkin, and the front I jack up each side on their own.
If I were doing an entire rotation I would use my hoist at work. Just easier.
I just use my jack to swap summer/winter setups.
If I did it again I would consider upgrading to their yellow fancy jack.
Discussion Starter #8
I actually used two jacks, the 3 ton HF and a no name 2ton, when I rotated my tires for the first time because I was afraid the HF (cheap) might not be up to the task. I definitely need to get bigger jack stand this summer because I'll be installing a level kit.
I use the 3-ton low-profile HF jack on my 2016 Platinum (20" wheels, stock suspension). While testing everything out for upcoming tire rotation, I found that the jack worked just fine (raises to 19 3/4"), but putting my Tundra on the HF 3-ton jack stands at the required jacking/support locations, even on their max height, resulted in the wheels touching the ground. Back to HF to get their 6-ton jack stands that have several more inches of height and I also picked up the Steel Floor Jack Cross Beam (Floor Jack Cross Beam). The cross beam attachment lets me adjust the pads to evenly jack-up the front end on solid points at the ends of the front cross member. I jack up the front end, slide the 6-ton stands (raised to three teeth showing) under the front frame support points, and lower the front onto the stands. Getting the original bolt loose from the saddle (10mm hex key and either a breaker bar or rubber mallet while bracing jack against garage wall) took a bit of doing, but it's now easy to switch between the two attachments.
The floor jack cross beam doesn't work for the rear, so I do a quick switch-out to the normal jack saddle, and raise the rear end under the pumpkin and slide the stands beneath the rear support points. For my truck, everything is level within a hair of perfect on the 6-ton stands with the front stands raised to three teeth showing and the rear stands at their lowest setting with no teeth showing. Wheels are off the ground and ready for impact wrench. I also added the rubber pads for jack stands (Rubber Pads for Jack Stands) to my 6-ton stands. Some pretty heavy whacks with a rubber mallet are needed to get those on, and they're on for good.
In case it helps anyone else, I found this universal saddle pad that fits the detents of the HF jack saddle: Jack Pad Universal. We don't need the frame rail cutouts for the Tundra, but the pad is better than putting a shop rag on the saddle.
The floor jack cross beam is rated for 2 tons and as others have noted, we're not picking up the entire weight of the truck at once. The instructions in the box list the 3-ton jacks as compatible with the cross beam, though the floor display model in HF, attached to a 3-ton jack, had a warning on it saying something to the effect of "for use on up to 2-ton jacks".
Good luck.
I use a 3 ton Craftsman floor jack for my Tundra. It has a good jacking height so that is no problem. Whenever I am working on one of my vehicles (Tundra or VW) I always use jack stands, etc in addition to the floor jack.
BTW, I don't know about other vehicle brands but VW Owners (at least of a certain age) refer to the stock VW jack as a "widow maker". Sadly there is a reason for that based on what has happened when these jacks failed when someone was working on their car.
Related to this thread: I use a 20 year old Craftsman brand 3 ton floor jack. It too leaks down a bit. Jack stands: check. All-in-all not too bad of a self perform job.
Unrelated to this thread. But perhaps related to this thread (I have a 2017 4WD, 5.7L): the absolute, whole hearted USELESS Mama Toyota jack that comes with the truck. Jeesus Christmus. I keep a hydraulic bottle jack and a milk carton crate full of 2x6's and 2x4's in case I need to "jack it in San Diego" along side the roadways of 'Merica.
Yea, the stock jack is useless unless you throw it through the passerby with a real jack in the bed hahaha.
Again, as for the jack, the HF 3 ton lp jack isn't bad. Mine doesn't leak down, neither does the used ass one at work.
Just the gdamned handle pulling out has screwed me twice. Once on my GN, once on my Tundra. Go to reposition and the handle pulls out.
For that reason alone, I would upgrade if I were looking at buying one and just buy the better SO equivalent supposedly jack.
At least the handle won't come out causing the control group to flip up and you have a jack stuck under your Grand National, or your Tundra.
I might just go bitch one day and see if they will swap me for an upgrade price. I mean, if you buy a good jack, you have it forever.
My jack I have wanted to throw across the driveway, but it was stuck under my car or truck at the time...
Ive owned my low profile harbor freight jack for 5 years now, been trusty and still use it to this day. Only rated 1.5 tons, but it has lifted everything ive owned and then some (tundra included)
I have the Harbor freight Daytona. It is leaps and bounds nicer than the 3ton low pro because I had that one before the Daytona.
The Daytona can get to it's max height of 23" in like 4 pumps.
It is very heavy like 200lbs so it rolls awesome.
Snap on sued HF and lost. It's the same as their 550+ dollar jack.
Here's my little review...
Good luck.
lando622,
Great write-up, and thanks for the hyperlinks. I just added them to my H.F. and Amazon shopping carts. I never knew that cross-beam thingy even existed!
Costco has an Arcan aluminum/steel 3T jack for right at $100. I replaced my leaky craftsman with one and it works great and doesn't weigh as much as a yugo.
1 - 20 of 37 Posts
