1 - 18 of 18 Posts
What backspacing would I need to have on aftermarket rims to be able to fit 295 70 18 nitto Terra grapplers with my ready lift 3/2 kit on my 08 DC TRD?
Discussion Starter · #7 · (Edited)
I know the stockers work but I'm confused as to what width rim and what offset in the aftermarket to shop for with this tire size that will fit without rubbing issues.
Mine are 18x9 +12 offset. I'm close to both my front fender and the body mount with my 3/1. To be sure of no rubbing stick with at most +18. Safe bet would be +35.
Reactions: snowtoy8
mine are on a 25+ backspace and barley stick out any they did rub on the mud flaps and a tiny bit on the splash guard when backing up
Reactions: snowtoy8
I had the same concerns prior to ordering my wheels. Most recomendations I have seen online are +18mm to +35mm offset.
I went with NittoTrail Grapplers 295/70R18 installed on 18x9 +25mm offset Raceline Raptors on my 2008 Tundra. I have no rubbing issues, the mud flaps were removed to install the fender flares. The truck has a Ready Lift 3.1.
Discussion Starter · #15 ·
Thanks. I feel your setup is close to my ultimate goal. I'm actually current looking for flares as well.
How close is close??? I ask because I've found some wheels I really like but they are 12 offset and I only have the 5100's at top setting and I'm curious about rubbing... oh and same size tires 295/70-18..
1 - 18 of 18 Posts
