Long time, first time. Here is what I'm planning. Coilovers set at 3" with Camburg uniball UCA's, 295/70/18 Trail Grapplers on 18x9 +25 Fuel Kranks. I was pretty much all set to go forward with this until I spoke to someone at MHT wheels. He told me that this wheel will rub the uca's. I thought I read here that others are running similar set up with minimal rubbing ( body mount, front fender). Is anyone running this way and rubbing their uca's?
Is there a difference between stock UCA and aftermarket like Camburg in how they sit? I have that exact wheel/tire combo but with stock UCA and the only rubbing I had was on inner wheel well lining and front mud flaps, no rubbing on body mount or UCA or anything else.
This set up won't rub on the UCA. I have same tire size, Camburg uniball UCA's, on +30 wheels. Tires rubbed on the fender liner and skid plate, which are both easily modded. No rubbing anymore, and definitely no rubbing on the UCA or body mount. You'll be fine.
Thanks for the replies fellas,
I am going to order the +20. Not much difference. The 25's are on backorder.
Gamer, How do you like your Camburgs. Much noise?
I have only had them on for about a week, but no noise at all. Some people say the uni-ball can make a clicking sound (this is normal), but I haven't heard it yet.
