2018 Tundra Limited
Good Morning i have a few question i am still new to the Tundra. this is my second tundra, but my first that i will be doing a lot of mods on and right now i just ordered a 3/1 RC Level/Lift and i am looking to keep the stock 20" Rims but wanted to see who out there know about tires i done some online looking and i have read many people have gotten the same lift with 34 with no problem and i wanted to to go the same same but just did not know if that is really possible.
TIA.
Vendor
Tire & Wheel Specialists
We have come across folks running the stock wheels with 275/65R20(34.07). Although as you found there may be some information discrepancies, a few reasons for this is due to the variables even within the save vehicle platform causing a tire to fit 1 vehicle but not another. Also perception of rub as well, what one may consider minimal rubbing may be a bit more serious to someone else. Lastly, variables in tire manufacturing that causes a tire to run a bit big in one brand and a bit small in another.
One thing you can do is physically measure the current tire and room you have to the nearest part you would rub. Then turn the wheel and measure at the closest point to determine how much bigger you can do.
That's with 2" in front 1" in back with 2756520 Falken wild peaks At3 only thing I had to do was bend in sides of skid plate a little bit
