So they said that they were just using the signal going to the factory sub with the JBL system. I saw two wires cut I believe because they used that wife to signal the sub. They obviously ran power wire and that controller line as well. I'll take a few pics of the factory sub when I get home. I'll weigh it too, it's so light I didn't even know if that sub has a magnet bigger then a quarter!!!where did you get your signal for the sub from?
head unit is the key alsoeach source has its own volume and audio settings....so switching from xm to radio will sound different, but i agree it is lacking. seems like adding amplifiers and different speakers/subs is the fix.
The Arc Audio Xdi series amps have high level input capability. So they just used the factory signal. No LOC necessary.So they said that they were just using the signal going to the factory sub with the JBL system. I saw two wires cut I believe because they used that wife to signal the sub. They obviously ran power wire and that controller line as well. I'll take a few pics of the factory sub when I get home. I'll weigh it too, it's so light I didn't even know if that sub has a magnet bigger then a quarter!!!
It seems like a lot of newer amps come with the signal level/line level switches now. The JL audio RD series comes with this. I altered from typical install by using a pair of 6x9 coax in front doors. This makes up for a lot of bass missing in the 6.5s. Granted this setup is not for the hard core bass guys but its quite sufficient for me. This eliminates the need for a sub and extra amp in some cases.
The system is a lot more affordable without the need of a LOC, Sub, or extra amp. To add to the affordable part I was able to grind out the existing speakers and use the existing mounts. AS an added bonus I did not have to worry about depth offsets because they are the existing mounts. Now to take it a step further for non jbl units I did not need to worry about a tweeter mount or crossover mounts since they are coax. It almost takes all the fun out of the install. =)
The install is a lot quicker in the doors and sounds great.
So let?s talk turkey here...What am I looking at spending if I want one of the best upgrades to my truck?
It's definitely worth the money though (assuming your install the components yourself). If you tried to source similar components separately, you'd be hard pressed to find a better deal.SQ1 is $2200? Too rich for my blood. I think the JBL sounds pretty good. Wonder if it?s worth the money for the cheaper packages. Anyone get the Taco Tunes system 1B for the 14+ CM?
I just did the 1B in my Tundra. I only matted the doors and rear. Will matting the floor make a big difference? I also added FAST rings to my mids. I was really impressed how clear and loud the system is. I may add the the EZ Curve later on. I was going to try an get appointment to see how much better is sounds with the sound processor.It's definitely worth the money though (assuming your install the components yourself). If you tried to source similar components separately, you'd be hard pressed to find a better deal.
I also spent quite a bit of time ripping apart my interior and applying sound matting (200% more sound matting than included with the SQ1 kit - I bought three packages of it to do the entire interior because the package deal from Taco Tunes only comes with one to do the rear wall and the door panels). I'm a self-described audiophile and I really love my SQ1 setup. Here are a few pics...
Matting the floors makes a big difference. A lot of the road noise comes through there.I just did the 1B in my Tundra. I only matted the doors and rear. Will matting the floor make a big difference? I also added FAST rings to my mids. I was really impressed how clear and loud the system is. I may add the the EZ Curve later on. I may try an get appointment to see how much better is sounds with the sound processor.
I was hopeful that they had made some improvements... And possibly that amp/dsp could be passed backwards. I wonder if the part numbers are the same?Looks like they haven't changed a thing for the 2018 model. I test drove one today and I had to try out their JBL system... TERRIBLE. Looks like I will be going aftermarket as well
thats the because the bit rate from pandora is pathetic. sound quality is awful.For my 2018 with the JBL sound, I was disappointed at first. However, after adjusting the eq settings on the HU, and setting the bass to max, the Mid and High somewhere around +1 to +3 then I was much more pleased with the sound quality. Mostly I just listen to Pandora or the radio. The sound doesn't blow me away, but it was better and I can be fine with it and don't need to upgrade the audio for now.
Then this last weekend, I discovered the best way to improve the sound in my 2018.... download music from iTunes. I bought an album and was listening to it and found the sound is much better when playing songs I bought from iTunes. I was really surprised at the quality difference. I'll have to get some more albums from iTunes because I think it sounds great now.
That's what I was thinking when I saw that while lying in bed last night.thats the because the bit rate from pandora is pathetic. sound quality is awful.
you got a little better quality when you downloaded the song.
also, if you want to stream with good quality, try Spotify premium they rip from lossless and stream at 320 kbps
I don't know how you have the bass all the way up on the stock system, if I did that my doors would rattle like no tomorrow while there is still no bass out of the sub.
that doesn't matter anyway as my entire stock system was ripped out, thank god, it was awful
ya I don't miss any of thatThat's what I was thinking when I saw that while lying in bed last night.
I had to up the treble almost to the max, mid at +1-2, and bass at neg 3-4 just to stop the doors from rattling and being over driven, and still being able to hear anything.
