Anyone have the same chart now for the JBL 2014-2015 system? I've seen the PDF schematic, but no color chart is included
I'm a little confused on the summing and full range terminology. I just got my 5 chl amp and LC7I installed today minus the subs due to no box, and noticed a big fall off in volume between the rear door speakers and fronts. I noticed it doesn't seam that the shop made any adjustments to the LC7I. The fronts are a thee ways and the rears are a two way because I like a lot of crisp highs. But It seems my rear door speakers are very dim on sound and seem to be pushing mids to lows.right on, much more detailed on the wiring then I.
I should point out that when summing the lc7i for output 3 (sub) it appears to sum for inputs 1 and 2 also. atleast it did for me.
I quickly looked at the lc7i and it shows the "connected to main channel" light on the right side on so im guessing they did sum the 3rd channel (sub output). But I'm still getting hardly any volume through the rear speakers. I will go back tomorrow and ask. I might wait till the subs are in to ask them to fully adjust everything.well as i understand you would "sum" the inputs for the sub woofer output so that it hs all possible signal to process and produce bass out of. If you were to somehow sum the front/rear left and right you would lose fade and or balance, which would be a downgrade of your ability with the stock system.
in your case bigdutchbag, it seems the amps and lc7i wasnt adjusted at all. my settings wont be helpful as we are probably using different equipment and listen to different music and other factors that would make settings different. in all honesty, I was never a sound system installer, my area was security and vehicle wiring. You would be better off having a professional sound system person adjust things.You should not have lost volume, in fact you should of gained volume in a properly adjusted setup.
Someone asked about wiring up a Line Output Converter using the 2014 Non-JBL factory amp wiring harnesses. The 2 harnesses that plug into the factory amplifier under the passenger side front seat have everything you need to install a LOC. I stole the idea from this post: Replace Factory amp powering door speakers (uh.. just a few pics). The OP had great pictures, but didn't include an easy to follow wiring diagram......
.....Now for the factory amp wiring diagram. The factory pinout diagram is a little confusing, so here is my explanation:
......In order to follow this diagram, hold the wiring harness you bought so the tab is on top and you are looking at the pins (looking "into" the harness).
File Type: pdf 2014 radio1.pdf
Hope this all helps someone out there.
tillithz, I am using the exact same equipment as you except I don't have a sub. Would it be helpful to me to have your setting? I have never adjusted an amp or LOC before.well as i understand you would "sum" the inputs for the sub woofer output so that it hs all possible signal to process and produce bass out of. If you were to somehow sum the front/rear left and right you would lose fade and or balance, which would be a downgrade of your ability with the stock system.
I installed mine the other day too, same issue, no solution unfortunately.So i got everything installed the other day by a local audio shop and my rear door speakers are so faint and muffled i can barley hear them, however there is audio coming out of them. The fronts and woofers sound great! I asked them about this and he didn't really respond with a great answer so im coming to you guys for some possible ideas. My setup is as follows (short and sweet).
Alpine 3 way 6x9 fronts
Alpine 2 way 6.5 in the rear
LC7i
JL 5 channel amp
fox acoustics w/ two JL subs.
I did see they summed the third channel as the "light" is on.
I haven't checked the wiring but figured it might be ok since there is still sound coming from the speakers, but you literally have to put your ear to the speaker to hear it. Would you guys have any ideas as to why it might do this?
I spoke to the guys with Audio Control and they said it might be they grabbed the wrong signal but didnt know why it would do that.I installed mine the other day too, same issue, no solution unfortunately.
I have three coming out of the LC7iDid you run one set of RCA's or 2?
First thing I would do is unplug all the RCAs in your amp except the front inputs, then move the front RCAs to the rear inputs so that the rear speakers are getting the front signal. If the speakers are still quiet it will rule out the LC7i, and its either a speaker wiring issue or an amp issue.I have three coming out of the LC7i
Great point. I am a diehard DIYer so I didn't think of that.good advice debremus. For bigdutchbag, you might want to hold the shop that installed it accountable. most places wont warranty things IF you touch it. I dont understand how you could have left the shop without it working, thats just poor service that the shop provided you.
So I went back to the shop and saw your post while at the shop. I pulled the wires and the rear speakers are wired correct and sounded just like the fronts when plugged into amp front out. Than I plugged my fronts into the rear out on the amp and it went muffled and showed the guy. He stated that it was due to the LC7i being summed between the 2&3 channel, and was basically working as a mid. (Or at least that's what I took from it)good advice debremus. For bigdutchbag, you might want to hold the shop that installed it accountable. most places wont warranty things IF you touch it. I dont understand how you could have left the shop without it working, thats just poor service that the shop provided you.
