2014 Factory Amp Wiring Diagram
171449 Views 218 Replies 60 Participants Last post by  purplenova
3
Someone asked about wiring up a Line Output Converter using the 2014 Non-JBL factory amp wiring harnesses. The 2 harnesses that plug into the factory amplifier under the passenger side front seat have everything you need to install a LOC. I stole the idea from this post: Replace Factory amp powering door speakers (uh.. just a few pics). The OP had great pictures, but didn't include an easy to follow wiring diagram.
This method requires no modification to the truck, which is good for lessee's like myself.
First off, buy TWO sets of Scosche Model: TA02B OR Metra 70-1761, or other brand of Toyota factory radio harness.
The larger harness that comes with these kits will plug into the factory harnesses at the amp, although one will have to be slightly modified.
The first thing I did when I received the factory harness was to pull out all of the wires and pins from the Scosche harness so I could rearrange the wire colors. If you look at the pins (at least in the Scosche ones, I assume its the same with any), there is a little tab that you can push down with a small flat head screwdriver to remove the wire and pin. I rearranged the colored wires to correspond with the factory amp wires. The Scosche wires were also labelled. This is NOT required, but it made it easier for me to remember what was what. For those unfamiliar with car stereo wiring standards, here is the list:
Yellow 12V Constant / Memory
Red Switch / Accessory
Black Ground
Blue Antenna Remote
Blue with White Stripe Amplifier Remote Turn-on
Orange with White Stripe Dash Light Dimmer/Illumination
Green Left Rear Speaker (+)
Green with Black Stripe Left Rear Speaker (-)
White Left Front Speaker (+)
White with Black Stripe Left Front Speaker (-)
Purple Right Rear Speaker (+)
Purple with Black Stripe Right Rear Speaker (-)
Gray Right Front Speaker (+)
Gray with Black Stripe Right Front Speaker (-)
NOTE: These are only the aftermarket stereo standards. I haven't found a vehicle yet that followed these standards.
You will also have to cut one of your harnesses so the larger factory amp harness will fit. It should be self explanatory, but look at the tundrageeks post above for a picture. You will need to cut one of the sides of the harness. I used a wire cutter.
Now for the factory amp wiring diagram. The factory pinout diagram is a little confusing, so here is my explanation:
In order to follow this diagram, hold the wiring harness you bought so the tab is on top and you are looking at the pins (looking "into" the harness).
If you look at the Toyota Wiring Diagram, you will see color code abbreviations. Here is the translation:
B = Black
W = White
BR = Brown
BE = Beige
L = Blue
V = Violet
SB = Sky Blue
R = Red
G = Green
LG = Light Green
P = Pink
Y = Yellow
GR = Gray
O = Orange
Note: I have included the colors as listed in the diagram. I did not confirm the colors, they are just included for convenience. Also note there are two white wires on the 145 harness.
The smaller harness, J144, has the power wire, accessory switched wire, ground wire, and the outputs to the front door speakers.
J144 (Smaller factory amp harness)
Pin 1 - Front Right Output to Speaker (+) - Light Green
Pin 2 - Front Left Output to Speaker (+) - Violet
Pin 3 - Accessory/Switched 12v [Remote In] - Sky Blue
Pin 4 - 12v Constant [Power] - Red
Pin 5 - Front Right Output to Speaker (-) - Blue
Pin 6 - Front Left Output to Speaker (-) - Pink
Pin 7 - Ground - White and Black (NOTE: The factory wiring diagram says that ground is Pin 9, but I confirmed that Pin 7 is actually the ground. It is a white and black wire. )
J145
Pin 1 - Front Left Signal (+) - Brown
Pin 2 - Front Right Signal (+) - Pink
Pin 3 - Rear Left Signal (+) - Light Green
Pin 4 - Rear Right Output to Speaker (+) - Red
Pin 5 - Rear Left Output to Speaker (+) - White
Pin 6 - Front Left Signal (-) - Beige
Pin 7 - Front Right Signal (-) - Gray
Pin 8 - Rear Left Signal (-) - Black
Pin 9 - Rear Right Signal (+) - Blue
Pin 10 - Rear Right Signal (-) - White
Pin 11 - Rear Right Output to Speaker (-) - Violet
Pin 12 - Rear Left Output to Speaker (-) - Green
If you want to power the factory speakers with your new amp or if you want to use factory wiring, you can run speaker wire to the output pins above from your amp. I tried both ways and ended up running new speaker wire only because I am picky. The factory wiring sounded good. The factory speakers also sounded surprisingly good when pushed with more power from my amp. I ended up running new wire because I put in component speakers in the front doors and wanted to keep the crossovers in the cab for easy access to the tweeter attenuation switch.
Because the J145 harness has two extra pins, you will have to manually plug in 2 pins into the factory amp harness. You can see what I mean in the following picture. Its a crappy picture of it all wired up before wrapping everything up and tucking it away:
The speakers in the dash still play, and actually add some nice fill. They are overpowered enough by my front speakers so they aren't an issue.
You could alternatively tap into the wires after the amp, but I was unsure how the amp processed the sound signal. If anyone else tapped into the signal after the amplifier, please post your results.
I installed an LC6I at the factory amp location. I did not remove the factory amp, as I wanted to keep everything as stock as possible, but it is obviously not plugged in. I am running a Kicker ZX700.5 amplifier which powers Infinity Kappa 60.9cs 6.5" component speakers in the front doors, with the tweeters installed in Platinum edition sail panels. My rear speakers are still factory, and they take the extra power from the Kicker amp surprisingly well. I built a custom box that fits under the rear seat and have a single 10" MB Quart shallow Mount RLP254 subwoofer installed. On retrospect, I should have built a dual enclosure and ran two of the subs. The one sound good, but I have to add some bass boost for it to be as loud as I like. I do enjoy the extra floor space for storage though.
Hope this all helps someone out there.
Reactions: 5
201 - 219 of 219 Posts
I will be connecting under the seat. I need to know which harness to order to make the connection before the amp.
My wife has my truck so I can't confirm this. But do I need to order the female or male version of the autoharnesshouse harnesses to connect my DSP on the HU side (removing the factory amp)?
why connect at the head unit and run wires when you can just plug in under the seat?
Alright so tonight went to tackle this mod and to my surprise and disappoment there IS NO FACTORY AMP under my passenger seat. Talk about major buzz kill. Now before you ask I have a 2015 SR Double Cab. My only solution that I can figure out to add an amp would be to tap into the harness on the back of the head unit. Can any of you audio gurus help me out here. What harness supplies audio signal to the speakers from the head unit? Does that also supply power? My plan is to just take the harness that holds audio signal and power and split it and running the power back to the head unit and the audio signal to a LOC then to my aftermarket amp and speaker signal out from my amp to the factory speakers. Thanks in advance.
I ordered the female version (the one at the top of the page, Item #: 4438) and it is the correct set of harnesses to by-pass the factory amp under the seat. Thank you all for posting this. It will make my installation Sooo much easier and CLEANER!
Okay, time for another dumb question. I bought the autoharnesshouse harnesses.
So I need to connect the "SIGNAL" wires listed in the first post coming out the factory harnesses and wire them to the corresponding AHH harness wires?
The "output to speaker" pins won't be used if I'm not using the factory amp... Right?
For example, on the factory J145 harness, pin is 10 is the Rear Right Signal (-) which I will connect to the rear right input (Purple with Black Stripe) on my AHH harness. Pin 11, which is the Rear Right Output to Speaker (-), I would not use since I'm not using the factory amp... Correct?
I just want to be sure before I go soldering/shrink-wrapping all these wires together.
Hi Guys,
I am the owner of a new 2017 Crewmax Entune Non-JBL truck, and I'm just catching up on this thread.
I have seen two pieces of conflicting information here and I'm wondering which is correct. One person says that the front audio to the under-seat amplifier is full range and that the amplifier low passes it to the front doors. Another person says that the head unit low passes the front audio to the amplifier. Any idea which is correct??
Thanks.
Michael
Hi Guys,
Thanks.
Michael
On my 2014 .. signal is FULL RANGE from the head unit to the amp. I believe it is that way for all years for the non-JBL trucks. JBL trucks I think may be a low pass signal. But, in your case, full range to the amp.
Thanks for your input. That is what I'm looking for, and hopefully it is the same on my 2017 non-JBL.
I'm putting in a re-curve unit and a 5 channel amp, and I want to retain the fader function from the head unit. If the front signal to the amp were to be low-passed, I'd have to derive the full range signal from the rear speakers, losing the fader function in the process.
Thanks for info, I've ordered a JBL system harness from Teech12Volt.com, don't know if there is any difference between your method and using just one harness?
I dug through this post, and really appreciate all the info that everyone has contributed. I don't see the answer to my question, so forgive me if I missed it!.
I installed an Alpine iLX-107 this last weekend. It honestly sounds like crap with the factory amp. I'd like to just bypass the amp and power my speakers with the Alpine head unit. Given the wiring color scheme posted in the first post, can I just splice input (i assume from head unit) to output to speakers under the passengers seat?
I am not sure how the front dash speakers are wired into the mix, so I wasn't sure if I'd blow up my Alpine with too low Ohm load if they're wired in series or parallel (excuse my ignorance).
I appreciate the help.
Jaye
Jaye
You need to bypass/remove the factory amp.
I used this thread to make adapters and install mine.
I ran RCAs from my Kenwood HU to my Alpine PDX V-9.
I then did all speaker connections under the passengers seat.
My rear doors run off my the HU and the front doors and sub run off the Alpine amp.
You might consider adding a 5 channel amp, since you will eventfully want a sub.
You can splice your connections under the seat and run your speakers straight off your HU.
Or better yet, make the adapters described in this thread so you don't have to cut any stock wires.
As to the 3 dash speakers, they run straight off the stock HU.
They don't go thru the underseat amp.
So if you wired the front speakers in behind the HU, your dash speakers run off the HU.
My Focal 2 way front door speakers gave me great front stage imaging and I ended up disconnecting all 3 dash speakers.
I first had them connected to the HU, but they were too in your face compared to my new Focal front door components.
Problem was there was no way to fade the dash speakers from the front door speakers.
But if you just bypass your stock amp and connect all your front and rear speaker wires together, you should have no problem running your stock speakers with your new HU.
Only issues you may run into is the funky ohm properties of the stock speakers..
Hope that makes sense.
Jaye
Makes a premade factory amp wiring harness instead of making your own..
AutoHarnessHouse
Ok guys need some help here. I installed my Kenwood HU and unplugged the factory amp. Connected all speakers to the harness on my HU, RCA outputs are correct on my HU and Amp. My speaker wires are ran from the harness on the HU to my 5 channel amp. I get no sound. Not even from the dash speakers. As soon as I plug in the factory Amp I get sound. So correct me if I’m wrong but should I run all 4 speaker wires straight the harness under the seat from my 5 channel amp using the wiring diagram provided in the first post? Or am I missing something? This is on a 2016 Tundra CM Non JBL unit.
Did you make your factory amp harness adapter or buy one already made?
So you are running RCAs from your HU to the amp and not using speaker level inputs on your amp, correct?
The oddest part of your post is that you're not getting any sound from your dash speakers since they run straight off the HU.
Also odd that if you plug the factory amp in you get sound with the new HU.
I almost sounds like a JBL issue but you don't have JBL.
On the headunit harness adapter I ran speaker wire from there to my amp. RCAs are running from head unit to amp.
I was referring to the factory amp wiring and the harness under the seat.
Essentially what this thread is about, making a harness to bypass the factory amp.
Are you sure the aftermarket amp is powering up?
I'm assuming you ran a line from the battery to power it.
What did you use as a remote to turn it on?
So you have RCAs from the HU to the amp.
How did you connect your amp to the door speakers?
Thru the factory amp harness, right?
If you're using RCA cables, why run speaker wire to the HU, is it for the dash speakers?
Are you running the front doors and the dash speakers off your front amp channels?
If you connected your new HU to the factory wiring, you should have sound out of the dash regardless of your amp, unless you rewired the dash speakers.
Just ran some test wires from my 5 ch. to my factory amp harness. Every speaker including the dash in ran through it. Any help to bypass this would be greatly appreciated.
So you can produce sound to every speaker in the truck from the underseat amp harness thru the amp speaker output?
I guess I'm not clear on what your issue is.
Since you won't answer my questions, I give up.
Good luck to you..
I think I am figuring it out. I didn’t have the speaker output wires from the HU connected to the adapter harness instead I ran speaker wire from the adapter harness to the amp. So my bad had to go through and double check everything.
Glad you are figuring it out. I just did this upgrade but with my factory HU.
I Couldnt have done it without the help of @1lowlife.
At least acknowledge the help he has provided.
