21 - 40 of 40 Posts
Discussion Starter #22
That some incredible work right there.
Makes me want to continue my work.
Thank you for great pictures and lots of useful information.
Looks like you're local. Let me know if you have any questions if you start back up with your install.
Discussion Starter #24
The last piece of the install is the Helix Director for the DSP Pro. I installed the Director into the sunglasses holder in the overhead compartment. I also extended the USB connector down the passenger side A pillar and under the glove box. With my seats installed I don't have access to the DSP and the Director allows a pass thru connection. Now I can just plug the USB cable I have connected under the glove box into my laptop make adjustments.
Picture of the glove box removed.
Your install is really coming along!!! I'm looking to try out the Helix DSP currently using BitOne Helix has more flexibility. I'm running Pioneer 4100Nex, Bitone, Audison 5.1k x2, Illusion C8 set, Hybrid L3se, and Illusion c12xl.
Holy shiznit! I had a sick feeling in my stomach just looking at pictures of your complete disassembly of the interior. You have big balls brotha.
Discussion Starter #27
I took the interior apart on my 08 when I had it. Our interiors are very easy to work with. Everything pops in and out pretty easily.
It sucks to see that the interior pieces for both my old SR5 and new Platinum are identical... lame.
I mentioned earlier I bought all my equipment from James Randy Taylor at Tech12volts.com and that his customer service was amazing. I’ll talk a little about that.
In addition to having the best prices for the things I bought, he was available to answer questions before I actually bought anything. He took the time to answer every question I had making me feel comfortable about what I was buying. I ended up buying a speaker box for my 2 SI BM MKIVs, a Helix DSP Pro, JL Audio HD 750/1, JL Audio HD 600/4, and Helix P62C components from him. I also pre-paid for a Helix Director knowing I wouldn’t have it right away. It took significantly longer for it to arrive than what I was told, but he kept me updated with what he knew. I told him I didn’t need him to ship it priority mail because a few days wouldn’t make a difference to me. I was hoping to pass along the difference in price to save him a few bucks, but he sent it priority mail anyway.
After getting the DSP hooked up he called me and walked me through the setup process. After getting it hooked up I ran into a problem and he called me again. The second call was around midnight his time. Try getting that kind of customer service from a big box store!
He’s an active member on TundraCrew on Facebook and many, many others have had similar experiences with him.
OK, back on topic and photos of my install……..
Tech12volt has built several complete systems for me and I consider him one of my closest friends . You will not find customer service like his anywhere. Your system is looking awesome man. www.tech12volts.com is the best for the Tundra period. Looks like he set you up with some awesome equipment
Discussion Starter #30 (Edited)
I didn't like where the director remote was located. Didn't seem like it fit well and there was some resistance when I closed it. And I wanted my sunglasses holder back.
I decided to move it to where the brake controller is on the newer trucks. If I ever decide to add a brake controller I can easily move the director. The panel I cut is also cheap to replace if I decided not to reuse it.
The controller has 4 holes for M3 screws in the back.
Great write up. Subbed for questions later
Great work.
Now I can see that the box my MK Iv's are in probably won't fit. It is taller. Depth wise I think it would though.
I bought my 14’ CrewMax Platinum last December and started my stereo install a few months ago. It’s taken me a little longer to get things finished because I changed my mind on a few things and had to wait for parts to come in. I wanted to document my install because hopefully someone will find something I did useful and use it in their own install. There are a ton of helpful threads already that I used for my own install.
Prior to this truck I had a 08’ DC that I did a stereo install on. For that install I replaced the HU, front doors with Polk MM components, rears with Polk MM coaxs, Alpine X power amps, and I went through a number of different subs (Polk, Kicker, and Stereo Integrity). I went all out with sound deadening and spent over $700 on materials from Don over at Sound Deadener Showdown | Sound Deadener Showdown . I started this is install only planning on adding some CLD tiles, but as the install went I changed my mind and added MLV and CCF.
I like the factory HU and didn’t want to replace it. This time I wanted to try better speakers running active and opted to not have any rear speakers. It’s rare that anyone sits in the back and the money saved from not buying rear speakers could be spent elsewhere. For the fronts I decided to go with Helix P62C components, Helix DSP Pro, JL audio HD 600/4 for the components and a JL HD 750/1 to power a pair of Stereo Integrity BM MKIV subs. Other than the subs which I had from my last install I bought everything, including the sub box from Tech12volts.com . His prices were well below anyone else and his customer service was amazing. I’ll get into that a little later.
Like most people I started by gutting the interior. How to do that has been well documented by others. Here are a few pictures of that process that includes CLD tiles, MLV and CCF. I used CLD tiles from sound deadener showdown and also reckhorn (Amazon.com: Reckhorn ABX 21.5 Sq Ft X 80 Mil Thick Self-adhesive Sound Deadener Aluminium Foil + Butyl Based Damping: Automotive ) tiles from Amazon (after running out of SDS tiles).
As I mentioned above I started the process not planning on using any MLV. I changed my mind as the install went and decided to try some MLV from Amazon. I bought 100 square feet for $219. That was the shipped price.
Amazon.com: TMS Mass Loaded Vinyl 4' X 25' 100 Square Feet 1 Lb MLV Acoustic Barrier: Musical Instruments
The price was cheaper than Don with SDS. I will say the Amazon MLV has a slight odor to it. It’s not bad, but it’s definitely there. Going back and reading through SDS’s website I saw where Don says he has sourced virgin material for his MLV. I still had a few pieces of his stuff from my last build and confirmed his stuff has ZERO odor. I kept the Amazon MLV but knowing what I know now, I would spend the extra money and order through Don. So far I haven’t noticed any odor and I hope it stays that way. I’ll find out next summer when it gets hot again. Here are some pictures of the MLV.
One of the videos I found on youtube that ended up helping me a lot was this
https://www.youtube.com/watch?v=h3EXuHlBy4M
The parts of the video most helpful had to do with sealing the doors and the tool associated with doing that. I ended up buying a threaded insert tool which helped with sealing the doors and later with my amp install. Here’s the tool.
Amazon.com: Surebonder 8510 6-32, 8-32, 10-24, 10-32, 1/4-20 Threaded Insert Tool: Home Improvement
If you search on youtube you can find videos on how to set rivnuts without the tool listed above using only a bolt and two nuts. Here are two videos that show what I’m talking about.
https://www.youtube.com/watch?v=AfQIYLSKGwI
https://www.youtube.com/watch?v=3Og-tHIR_0I
For my doors I used smaller 10-24 bolts to attach plastic to seal the opening. I didn’t realize when you use a bolt that small you’re forced to use a screwdriver… at least I wasn’t able to find anything at the local hardware store with a hex head for a 10-24 bolt. I was able to set a few rivnuts without the tool but ran into problems when the surface wasn’t flat. I broke down and bought the tool which made the process simple. If I had to do it again I would try to use larger bolts than the 10-24 I used. I think I would be able to get away with not using / buying the tool because the larger bolts would have a hex head and allow for a better grip over a screwdriver.
After watching the “increase midbass video” I tried to find cheap ABS plastic to use to seal the large opening in my front doors. I wasn’t able to find anything reasonably priced. I also tried to find the TESA paint protection tape like the stuff used in the video, also with no luck. I ended up using cutting boards instead of ABS plastic I bought from Walmart and carpet protector rolls from Home Depot. Here’s what I bought.
I added CLD tiles and butyl rope to the front doors to deaden them.
Then I used the clear carpet shield to trace the opening in the door which I transferred to the cutting board. I used a jigsaw to easily cut the cutting boards.
I also bought some peel and stick ensolite from RAAMaudio - Automotive sound deadening products that I used to cover the cutting boards. The following photo shows both openings in the door covered. I ended up having to remove the top piece. I didn’t take into consideration the thickness and wasn’t able to get the door card back on.
I bought my speaker adapters from How do I install stereo, speakers, subwoofer, amplifier, tweeters ipod in my Tacoma Toyota that I also covered with peel and stick ensolite.
After mounting my speakers into the tacotunes adapters I used some Sound Connection 6 ½? F.A.S.T. ring kit Sound Connection on them.
If you haven’t noticed already I bought some TESA tape to wrap the factory wires. I also used the tape on the door cards to try to keep the door clips from rattling. Putting the tape on the mounting points on the door made the door clips more snug.
I added CLD tiles, ensolite, and 3M Thinsulate I had left over from my previous install on the door cards / skin. I also removed the Styrofoam from the door card because I covered the hole using the cutting board. I also had to cut away some of the plastic “fins” on the bottom of the door card to get it to go back on correctly.
..... TO BE CONTINUED .....
Great !!! You did an awesome job... Thanks for sharing, it looks like a great manual of DIY for modifying a sound system. Appreciated.
I just have a dumb question! How I can see the pics? Photobucket says I have to update my account.... any idea?
Discussion Starter #36
The issue is with Photobucket on my end. Their policy says I can't host them on another site so all the photos are blocked.
Discussion Starter #38
2020 Tundra TRD PRO
Wow...quality work you put in there...(y)(y)(y)
Great write up! Would love to see your RTA results when you have the systems finished and dialed in.
21 - 40 of 40 Posts
