Hey all,
As the title states, my interior cabin lights and the bed light on the exterior back of the cab flicker constantly when the doors are open or if they are manually turned on. The door switches seem to be ok, I tested them by checking for continuity with my volt meter. I am not sure what else to check or what I should do, and the dealership has pretty much asked for a blank check to troubleshoot the issue. Any suggestions on what I can do, try, test before handing over a blank check? Thanks in advance.
Sam
Discussion Starter · #2 ·
I've checked the battery terminals, removing them and cleaning up any crud on both + and -. The issue persists, both when running and not. Any assistance is much appreciated!
Free Tire Finalist
Did you buy the truck used? Did someone install LED bulbs? Sometimes cheap or loose LEDs will flicker.
Could it be something else within the system that's aftermarket. CB, aftermarket stereo etc.
Sent from my SM-N975U using Tapatalk
You've done some of the troubleshooting, good.
1) check the contacts on all bulbs which light up, making sure all do light up. (each bulb in/out 4 times)
2) check the connector on the switch to turn the lights on/off. (VOM ohms between the ON terminals should be 0.)
If all are good, keep checking. Remove all the light covers. Take a pencil and tap the eraser against each bulb, looking for the flicker. (It could be a broken filament which momentarily disconnects causing bright/dim/flicker.) Check the grounds if the bulbs ground at the light housing. Pull the fuse for the cabin lights and reinsert several times. If there is a relay for the cabin lights, check its ground. The last thing I can think of is to support the wiring which goes to the manual switch for the lights. Add a wire tie if it's loose, remove a wire tie if it's too tight, moving it back until there is no strain.
Hi all, following up. My issue ended up being the dash switch that manually turns the cab lights on. It was damaged somehow and had a split wire. Once I fixed that, I have been good to go. Thanks for the feedback!
