Hey All,
I am new to the world of Tundra's and am in the beginning phases of planning out the lift for my 2014 CM SR5. I have spent countless hours sifting through the wealth of knowledge on this site and still have no idea what route to take. You all provide so much information I begin second guessing myself and just can't finalize my decision.
I am looking for an aggressive stance with a small amount of wheel offset yet still functional on the paved road. I'll be doing some off road in Colorado and pull a 4,000lbs camping trailer on the weekends. I am looking for some rake so that I am more level when I am hooked up to the trailer.
Based on the research I have done, here is what I was thinking. Please shoot any holes in it or provide any other suggestions that you might have.
For the Front
-OME 614s kit 1 CB shim on each side
-UCA's
-Diff drop kit
-+3 CB Shackles + poly bushings
-Toytec Add a Leaf
Tires
295/70r18 Cooper STT Pro or Nitto Terra Grappler (Not sure if these would work and completely open to other recommendations)
Wheels
Fuel Trophy 18x9 +20
Looks good to me. I'm not sure how much rake you'll have maybe 1.5". With OME Dakar springs and coach builder +2 shackles in back and OME 614 without shims I have 2 inches rake.
You will want to add a carrier bearing drop to your list and poly bushings to go with your shackles.
edit. see your already going with poly bushings. Nice!
Discussion Starter #4
Would you have a picture of your truck that you could post? I've accounted for the poly bushings but not the carrier bearing drop. Thanks for the input.
