1 - 4 of 4 Posts
After about 7 hours on the interstate I stopped to get gas. Once fueling was complete the truck would turnover but not start. I removed the negative battery terminal. I reseated the fuel pump relay. None of these events seemed to have a direct impact. After 15-20 minutes it finally started. I started the truck several times over the next few days with no issues until I got gas again. Pretty much a repeat of the first event.
After some research I suspected a possible immobilizer issue but had no starting issues. I was out of town so on my return home I left the engine running while refueling to avoid being stranded. A couple days after I returned home the truck issued a check engine light with codes related to EVAPORATIVE EMISSION LEAKS P0441 and P0455. The Auto Zone clerk said it might be from running with the cap off while refilling. I cleared the codes and ran down the last of the gas in the tank from the trip.
Today I went to a less busy filling station, anticipating a lengthy stall, and I refilled to about a gallon below full. The truck would turn over but not start. I tried waiting 15 minutes, 20 minutes thinking the error might time out. No success. I lifted the battery cable for a few minutes and tried unsuccessfully several times. After a total of about 40 minutes of not starting it finally started.
I've seen issues with fuel pump ECU and fuel pump itself. Does anyone have any experience with this?
Have the dealership check your fuel density...its probably too high.. if its a flex fuel tundra.They just reset it.
Discussion Starter #4
For the purposes of archive, the problem was resolved by replacing the purge valve on top of the engine. $90 part at O'Reilly's. When the valve fails it allows gas tank vapors to get into air intake. Not sure exactly how that prohibits starting after refueling. I also observed about 1-1.5 mpg improvement after replacement. I originally thought my economy reduction was new tires but it was likely a failing purge valve reducing my mileage.
1 - 4 of 4 Posts
