If you have a sunroof, check the drain holes. I believe there are one at each corner
I do have a sunroof and I will check it. I also noticed even after a while with my truck running there is no water leaking from the bottom when the ac is one. Does that me it’s clogged?
Also thank you for the advise Danny3737
If you do not see condensation on the ground near passenger firewall, then ac drainage is blocked. You can access the drainage tube from outside/underneath to clean.
The sunroof drainage holes are typically in the rear of the sunroof pan. A hose typically routes the watery down the B or C column with the end positioned at an opening at the bottom of t the body shell. Use long flexible wire at north ends to clean out.
Sent from my Pixel 5 using Tapatalk
