Picked up this 2013 SR Texas Ed a few weeks ago. Things have warmed up and I finally got a chance to open dash etc to swap the radio and install other things. Items in process:
  • radio swap
  • figure out how to tap the oem Mic
  • bypass automatic outlet switching
  • install hard wired detector power
  • remove/replace old radio input with a dual usb power outlet
Looking for a unlit rocker switch to manually control the power supplies listed. If these supplies are on, I don't want the switch to be out up when the truck is off (ie overnight).
I do understand the need to alert the driver of a high amp device is on and could kill the battery. I'm only looking at low amp requirements (ear bud charger). So, looking for old school rocker switch that will for the dash openings.
