1 - 19 of 19 Posts
Vendor
SDHQ presents an easy way to mount a winch on your 2014+ Tundra while maintaining the stock front bumper. Slight modification and trimming to the stock bumper plastic is required to allow access to the winch line and fairlead. Our winch mount is CAD designed for precise fit and is constructed out of 1/4" thick mild steel. Precision bent and mig welded for strength and durability. After initial construction, the winch mount is powder coated matte black for a nice, long lasting finish that will withstand anything you can throw at it!
The SDHQ winch mount has been designed to fit the Warn Zeon 10 Platinum series of winches with wireless controller. Other winches that are similar in size with the same bolt pattern may fit but are in no way guaranteed to fit by SDHQ or its distributors. We at SDHQ recommend the Zeon Platinum series winches because they have a wireless controller which allows full functionality of the winch. Winches with a manual clutch will not have the ability to "free-spool" unless a device is built to access the winch's clutch release.
Relocating the winch control box on the Zeon series is necessary due to clearance issues. We have optional kit that includes all the wiring and hardware needed to relocate the Zeon series control box. Relocating the control box is possible without our kit; however, the end user will need to source their own wires and hardware.
Key Features
  • No Drilling Required
  • Bolts Directly into frame and adds support to Bumper/Frame Horns
  • ¼” Thick Steel Plate Construction for Durability
  • Designed specifically for the Warn Zeon 10-S Platinum with Wireless Control
  • Optional Control Box Relocation Kit
2014+ Tundra Hidden Winch Mount
Vendor
The price is right for the winch mount but it's made specific for the Warn winch. There is no way I'm gonna spend that much on a winch because I will never even that much winch for my usage. My question, is there any other winch that will work? Also, is there two different option we can choose from? The top two pictures shows they are different.
Vendor
Discussion Starter #6
We opted for the Warn winch for a couple different reasons. The Warn Zeon Platinum 10 and 10-S winches have a wireless controller to allow full functionality of the winch. This allows you to unlock the clutch so you can free spool the winch line when needed. The Warn Zeon series winches also have a removable solenoid on the top of the winch allowing you to easily relocate to somewhere else freeing up much needed room behind the front bumper. Also, Warn is known in the industry as being the best performing and most reliable winch on the market. As winches are rarely an item that is used everyday it is nice to know that when you need it, the winch will turn on, function and be ready to get you or a buddy out of a sticky situation.
We only have one winch mount model; however, it is designed to work with either a steel cable winch with a roller fairlead or a synthetic line winch with a hawse fairlead.
Thanks for the reply. I know Warn are popular but at that price not everyone will be able to afford it. Just wish their were other option. I'll place my order when I can stomach it. Thanks again.
Sent from my LG-D850 using Tapatalk
any discounts now or upcoming for forum members, I am thinking of ordering this. also will it work on 2008 with warn 12s zeon platinum winch??
Vendor
Yes, we have a running special for TT members. We have not test fit on a 2007-10 yet but we suspect that it will work The Zeon platforms all have the same size body so a 12k will fit in the mount itself.
Thanks for a great set of instructions. how do I go about ordering this?
what is TT member discount? and how does one go about getting it?
Vendor
shoot me a PM and I will get you all set up or you are more than welcome to order through our website and I will calculate the TT discount before shipping!
1 - 19 of 19 Posts
