2008 tundra ..ABS CODE C0278 - OPEN CIRCUIT IN ABS SOLENOID RELAY CIRCUIT ....PLUS SECONDARY CODE C1310 1, EV SYSTEM MALFUNCTION 2. HV SYSTEM MALFUNCTION
!! HELLO PLEASE HELP !!
WHEN I START MY TRUCK NO BAD DASH LIGHTS ARE LIT... I DRIVE, ONCE I HIT 15MPH THE DOORS LOCK, AS NORMAL, AND AT THE EXACT SAME TIME THAT THE DOORS LOCK..... THE DASH LIGHTS UP! BRAKE LIGHT, ABS LIGHT, VSC LIGHT, TRACTION LIGHT ALL LIGHT UP AND I LOOSE THE ANTI LOCK BRAKING AND TRACTION FUNCTIONS...
CAN ANYONE PLEASE TELL ME WITH THESE CODES AND SYMPTOMS WITH WHAT THE PROBLEM IS?? I THOUGHT IT WOULD BE AN ABS RELAY BUT THIS TRUCK DOES NOT SEEM TO HAVE AN ABS RELAY. SO NOW I'M THINKING ITS THE ABS MODULE AND THAT THE ABS SOLENOID RELAY MAY BE PART OF THE ABS CONTROL MODULE????
LIKE I SAY PLEASE HELP!!!!!
