I have noticed that when I press the brake the truck seems to "drift" a little one way or the other. If you go into a curve and turn to the right it will drift a little to the left and vice versa for the other side. I just replaced the driver's side tie rod end and the 2 big sway bar bushings that mount to the frame. (One on each side). The 1st time I felt it I thought the front end was hydroplanning a little. Scared the piss of me. Lol.
I think I would get the alignment checked and double check the work you did.
Really can't screw up what I did unless you just don't tighten things back down. Lol. Just thought of something as I was driving awhile ago but I don't know they are called. There are some big rubber bushings where the a frame or whatever mounts to the frame. Those could be worn
