My 2000 Toyota Tundra had the rusted out frame issue and was recalled for a complete frame replacement. They did NOT replace the corroded power steering pressure hoses or the fittings now I have a hydraulic fluid leak at one of the locations where the solid tube was connected to the frame. Does anyone know if Toyota will fix this problem as a part of the frame recall?
Can't hurt to ask. At this point I doubt they'll do it. Might not be too expensive to have an independant do it. I *think* they would replace brake lines when doing the frame change, those are what I'd be worried most about.
How Long ago did you do the frame replacement? Any chance they could have damaged it during the swap? That's the route I would exploit....assuming it hasn't been very long since the swap.
