1 - 20 of 20 Posts
1794 Edition 4.5" BDS/Fox Coilovers Build
2016 1794 Edition 4.5" BDS/Fox Coilovers build with Icon UAW, 20x9" XD wheels, 34" Toyo ATII's, TRD Pro grill, Amp Research steps, Headlight Revolution LED's. Work was done by Premier Off Road and Performance.
Nice setup Ortho; almost did same with mine but then decided to go with my King setup instead with a slightly lower lift. The 4.5-inches look more like a 6-inch lift in the photos. How is the ride with the BDS/Fox combo and Toyo ATIIs?
Thanks! It does! I'm on 34's so actual lift is 5 1/2" in the front and 4" in the rear. I chose this lift so that I can still park in my parking garage at work which is 7' 0". With the bigger tires and lift, I managed to fit with less than 2" to spare. The ride is very good! At low speeds its a tad firmer than stock but feels about the same at higher speeds. However it soaks up bumps and potholes much better and has a much more controlled feel. The Toyo ATII's surprisingly are much louder than the K02's I had on there before.
If you dont mind me asking. What did your lift and tire package run you without the grille install? Just getting my head wrapped around what I want to do with my truck.
If you mind me asking what did your lift and tire combo run you including install minus your grille? Just getting started to wrap my head around a lift for my 2014 limited.
Thanks advance.
Discussion Starter · #9 ·
Lift $3100
Lift install $800
Wheels $980
Tires $1261
Mount/balance $225
Freight $500
Alignment $100
Tax 8.25%
Very nice! I chose a RC 4in and 34in tires for the same reason - garage is 6ft 11in. I should just be able to slide under.
First, Great job on the truck. Got my wheels spinning and planning. To that, I've got a question.
Yours started life as a 1794 Edition with a TRD Off-Road package. So, what is remaining of the TRD package that would not have been included on the 1794 Edition without the TRD Off-Road package?
Thanks! Yes, you should just barely squeeze by.
Discussion Starter · #14 · (Edited)
Thanks! Actually, mine did not have the TRD package. I added the stickers after doing the lift. Sorry, I know it's misleading but I really liked the stickers. If you look at my before pic you will notice there are no stickers.
Discussion Starter · #16 ·
#goals legit considering this. A local off road shop just became a BDS dealer. They’re runing a special right now, $3600 out the door..tax/ alignment included.
Sounds like a great deal! If that price is includes the fox coilovers that would be $400 less than what I paid.
Discussion Starter · #18 ·
Thanks for that. No sweat, I thought about doing the same. Build your own TRD Pro.
Discussion Starter · #20 ·
SDHQ Hidden Winch Mount/Warn 10S Platinum Winch
I had a SDHQ Hidden winch mount and Warn 10S Platinum winch with wireless remote installed. Very pleased with how it turned out. Next planned mod is a Headlight Revolution 32" LED light bar which will be installed behind the grill just above the bumper.
1 - 20 of 20 Posts
